Bleeding the clutch '93 F150
Old 07-13-2008 | 08:28 PM
Stosh's Avatar
Default Bleeding the clutch '93 F150
I just finished swapping out my 4-speed transmission for a 5-speed in my 1993 F150 XLT. I also had to switch the transfer case and drive shafts in the process. I installed a new clutch slave cylinder, and cline between the master and slave cylinders, and have to bleed the system. The manual that I have says that it is a gravity fed system and to loosen the bleed screw and maintain the fluid level in the resevior. I have done the above, but after 7 hours, very little has happened. I get an occasional small bubble coming up into the resevior, but nothing is coming out of the bleed screw yet. Any suggestions on speeding up this process?
Old 08-30-2008 | 12:06 PM
jawint's Avatar
Default RE: Bleeding the clutch '93 F150
I've had to bleed the clutch too, all you do is have one person sit in the cab, the other will loosen the bleeder screw, then have the other person push the clutch to the floor, then tighten the screw back up, and repeat til it is done. i notice that it isn't really gravity that does it. i too have a 93 f150 and thats what i did.
mike93range
07-20-2010 03:56 PM
paf150driver
03-28-2009 02:25 PM
91F150XL
03-21-2009 07:15 PM
Coloradoskier
01-04-2009 04:46 AM
BILL PORCELLI
11-01-2008 12:54 PM
