Brake Line Question
Old 04-14-2008 | 07:56 PM
sbcadillac's Avatar
Default Brake Line Question
I had to replace the front brake line in my 93 F-150, the one that runs across the front axle from the left to right caliper. Problem is the line I bought is just a little too long and I cannot cut and flare it. Would it be ok just to add a loop in the line to take up the slack? or would that have a negative effect on the braking? I wouldnt think it would matter much but I wanted to get some opinions. Thanks - Logan
Old 04-14-2008 | 08:09 PM
david paul's Avatar
Default RE: Brake Line Question
THAT WOULD BE FINE AS LONG AS IT DOSEN'T RUB[VIBERATE] AGAINST ITSELF OR SOMETHING ELSE
Old 04-14-2008 | 08:10 PM
david paul's Avatar
ALSO MAKE SURE YOU DON'T PUT A KINK IN THE LINE
Old 04-14-2008 | 08:54 PM
sbcadillac's Avatar
Good, that'll makes things aloteasier. Thanks
Old 04-17-2008 | 01:20 AM
Bullitt94's Avatar
Yeppers, I had to do the same out of my master cylinder. A sweet loop-dy-loop before the next connection. It works just fine. Like davis paul said, be sure you don't kink the line.
Old 04-17-2008 | 01:59 PM
sbcadillac's Avatar
Bent the new line into shape, threw in an extra loop, and she seems to work good. Thanks
mr_cb7
05-26-2012 10:15 PM
skilletrx
09-24-2008 10:01 AM
chester
09-28-2007 06:47 AM
QC24
11-02-2006 11:25 PM
Double D
08-30-2006 12:21 PM
Quick Reply: Brake Line Question
