Brake Line replacement
If you live in an area where rust is a problem, yes, you will need to have those lines replaced and believe me, it is no picnic. They do now have coated brake lines available at various auto supply stores and that helps control the rust problem.
If you can shop around , I'm pretty sure you will be able to have them replaced for a lot less.
