brake pedal goes to floor....?
Old 05-12-2010 | 11:44 PM
hicksw00's Avatar
Default brake pedal goes to floor....?
I am baffled beyond belief. I have a 95 f-150 and the brake pedal goes to the floor. if you pump it it will get slightly hard, wait 2 secinds push pedal, right to the floor. i have bench bled master cylinder, bled brakes countless times, replaced master cylinder, one front caliper, and adjusted the rear brakes to the drum. one problem i think it might have is when you push the pedal air bubbles come up in the rear of the master cylinder tank. i don't know if there is a hole in the tank or the rubber is leaking by. any thing would be great!
Old 05-13-2010 | 09:55 AM
Bullitt94's Avatar
Sounds like there is a leak in the line somewhere. You'll have to follow the line back to see if you can find a leak.
Old 05-14-2010 | 07:14 AM
hicksw00's Avatar
i found the problem! i bought a used master cylinder with a tank, and the air leaking back in the tank is gone. i have hard brakes! thanks for your help..
petec
07-26-2012 10:57 AM
welderbill
09-06-2011 09:02 PM
petec
05-21-2011 12:55 PM
WindstarWorkHorse
12-21-2007 08:56 PM
cope607
03-13-2006 04:56 PM
