c6 transmission
Old 03-01-2008 | 10:36 PM
joemar6988's Avatar
Default c6 transmission
93f150 4x4 had a e4od in it and i have a c6 to put in now that i just blew my trans, altho every shop ive talked to said this isnt a problem to swap the bolt pattern on my 302w is completely different from the 351c that the c6 came from. anyone have and input on this that would b great b4 i spend a couple g's at an actual shop thanx
Old 03-02-2008 | 07:36 AM
david paul's Avatar
Default RE: c6 transmission
351c is a big block won't interchange
351w is a small block it will interchange
Old 03-02-2008 | 02:38 PM
joemar6988's Avatar
thanks that helps out alot
Old 03-02-2008 | 02:43 PM
joemar6988's Avatar
does this mean im goin to have to reuse a rebuilt e4od or is there a trans just as strong as the c6 that i can use that will with on the 302w
Old 03-07-2008 | 04:36 PM
peanut2008's Avatar
You are also going to lose overdrive and some fuel milage with the C6
