cables and dash
Old 01-21-2012 | 04:25 PM
fordka's Avatar
Default cables and dash
how do you disconect the throttle and parking break cables on a 95 f150. also how do you remove the dash. the ends are freed up mostly but the center is still stuck somewhere. i dont know what else to do. any help apretiated
Old 01-21-2012 | 04:46 PM
The cable for the parking brake connects at the parking brake mechanism at the pedal goes down through the floor down to the approximate center of the vehicle where it ties in with the adjuster and the two rear brake cables. I have never seen the front part bind up , but the rear ones , yes like very often especially when not used regularly.
Most of the time the rear ones were very difficult to loosen up and I wound up replacing them. They can be a PITA to replace too. If you are determined , you can do it, but it will take some time and effort.
Throttle cables were fairly easy to lube and get working again . If my memory serves me correctly the throttle cable ends just came off a ball stud if you pulled hard enough. Then all you had to do was pinch the plastic casing retainer and it would release , installation was the reverse of removal.
Old 01-21-2012 | 04:53 PM
fordka's Avatar
i am removing the cab and have to disconect everything. the cables arent stuck it is the dash. i just need to know how th disconnect everyting without breaking anything. thanks
Old 01-21-2012 | 07:10 PM
I'm gonna pass on this one because you need to work as you go and you will see what's attached and needs to be disconnected. Just take your time many parts of the dash are plastic pop in fit and come apart the same way. What isn't snap fit is held by screws that you can readily see. Sorry I can't be of more help.
Old 01-21-2012 | 11:59 PM
fordka's Avatar
ok. the problem with the dash is that i got the 2 ends to pick up abit but the middles still feels stuck and i dont want to pull on it afriad of breaking even more that what i already have. thanks. cables i dont see how you would ever replace one if you needed to. just somany complicated things. thanks
jkdodd
03-22-2017 10:22 AM
jvcoach23
08-19-2015 03:38 PM
caper74
04-25-2008 02:11 AM
a1parrothead
11-21-2004 03:52 AM
Quick Reply: cables and dash
