Camber/caster adjustment
Old 04-30-2008 | 09:11 PM
CW's Avatar
CW
Default Camber/caster adjustment
I installed a lift in my 91 F-150 4x4 and wanna get the alignment close so i can drive it to the shop to get it done. I have never adjusted a ford before so im just looking for the proper procedure.
Old 05-03-2008 | 02:12 AM
jr78's Avatar
Default RE: Camber/caster adjustment
If the alignment shop is not to far I would take a tape measure and set the toe close to 0 and drive it to the shop. It really is to much work just to get it close enough to take to the shop.
But if you want, and you have the shims you will need to remove the nut from the upper ball joint, drive the old shim out, install the new one in a position you think will be close to what you want and reinstall the nut. After doing that you will need to set the toe close to 0.
Old 05-03-2008 | 02:14 AM
CW's Avatar
CW
Does it need new shims or can the old ones be adjusted?
Old 05-03-2008 | 08:54 PM
jr78's Avatar
If they are the factory ones, then they can't be adjusted. They would need to be replaced with one that has the correct degree offset. If they are aftermarket then some can be adjusted and some can't.
Old 05-03-2008 | 09:19 PM
CW's Avatar
CW
I was checking it out closer today and it looks to me like it has the 92+ style adjusters in it.
I moved it around today a bit and it has settled almost straight by eyeballing it. It did sit in at the top a little before the lift so maybe i just straightewned it out. Lol
rcoelho
02-13-2022 08:52 AM
lbf250
05-03-2008 10:25 AM
sbcadillac
04-11-2008 12:49 PM
spinbad
12-22-2006 01:27 AM
Kjack
03-07-2006 04:14 PM
