changing out the block heater with a freeze plug
my block heater once fell out and lost my coolent , i dont trust this after time ...... guess it comes out easy but the new freeze plug should just tap in easy ? 1998 5.4 motor
You need to make sure to make the edges of the hole as clean as possible and we used to use a non hardening sealer like permatex and just make sure you push in the center of the plug just enough to make it expand in the hole.
If you have a recessed cup type plug you can use a wooden piece of tough dowel to insert it.
