changing out fuel injectons
hello i have a ford f-150 1991 4.9 300y L6
my question is i am wanting to change my fuel injection over to reg carb
my friend has a ford f-150 older than mine but same motor but his is carb engine and mine injectors. was gonna buy the carb and intake from him but was wondering if it will hook right in my truck without any probs. thank you for your time.
RE: changing out fuel injectons
It'll be much easier to fix the existing fuel injection system. Fuel injection systems have a much higher fuel line pressure. If you put in a carb, you'll have to install the fuel pump and filter from the old truck, too. Chances are, the gas tank, ECU, and ignition system are different between the two vehicles.
