Check engine light flickers
I just got a really good deal on an 88 F-150 4x4 ext cab with a 5.0L 5spd that the clutch fan had come apart on and took out the water pump bearing and rad. I have fixed all that but when i drive it the check engine light flickers quite often, it seems to be running good but im just wondering why it would flicker and not just come on and stay on for awhile?
RE: Check engine light flickers
A bit of an update..................
I drove it all day today and it looks like its flashing codes while its being driven. But if it is its almost every code possible. The truck runs awesome so i dont get it.
Did you get the codes Checked?
You should have an ODB I so you could pick up a reader which is relatively cheap (around $40 or so) at most auto parts stores or just use a paper clip to jump the contector just inside the hood. If you want I'll get you all the proper info on doing this.
once the connector is jumped its as easy as watching the check engin light flash,recording the number of flashes and then matching up the number of flashes and sequence to the codes. I am sure when I did this the code list was on this forum. If not a quick search in google should do it. If you have trouble getting the codes let me know and I can find what I used.
Having said all that when my check engin light was flashing it kept showing up as a EGR valve problem. Which in actual fact ended up being a vaccum leak. On of the hoses was broken, fixed that and the light went out. So one place to start might be to check your vaccum lines, that is other than getting the codes read.
Hope this help a little.
Andy - GWN
89 Ford F150 5.0L EFI
Andy - GWN
You can use an analog volt meter to pull the codes. Just count the sweeps to get the code numbers. All OBD I codes are 2 digits.
Example: sweep, sweep, sweep, sweep (pause) sweep, sweep, sweep, sweep, sweep, sweep, sweep, sweep = 48
A 48 would be the fault code for "Injectors unbalanced "
Diagnostic Trouble Codes - 1988
Ford
11
System "pass"
12
RPM out of spec (extended idle)
13
RPM out of spec (normal idle)
14
PIP was erratic (continuous test)
15
ROM test failed
16
RPM too low (fuel lean test) **
17
RPM too low (upstream/lean test) **
18
No tach
19
No power to processor or idle speed incorrect
21
ECT out of range
22
MAP out of range
23
TPS out of range
24
ACT out of range
25
Knock not sensed in test
26
MAF (VAF) out of range
28
Ambient temp. below 50° F (1.9L EFI & 2.3L Turbo only)
31
EVP out of limits
32
EGR not controlling
33
EVP not closing properly
34
No EGR flow
35
RPM too low (EGR test)
36
Fuel always lean (at idle)
37
Fuel always rich (at idle)
41
System always lean
42
System always rich
43
EGO cool down occurred
44
Air management system inoperative
45
Air always upstream
46
Air not always bypassed
47
Up air/lean test always rich***
48
51
ECT input too high
52
Power steering pressure switch is open or steering wheel not turned during KOER self-test
53
TPS input too high
54
ACT (VAT) input too high
55
Electrical charging under voltage
56
MAF (VAF) input too high
58
Idle tracking switch input too high (engine running test)
59
Trans. hydraulic switch (THS 3/4) failed in open position (3.0L & 3.8L A/T only
61
ECT input too low
62
63
TPS input too low
64
ACT (VAT) input too low
65
Electrical charging over voltage
66
MAF (VAF) input too low
67
Neutral drive switch drive or accelerator on (engine off)
68
ITS open or AC on (engine-off test)
69
Trans. hydraulic switch (THS 3/2) failed
72
No MAP change in "goose test"
73
No TPS change in "goose test"
74
Brake on/off switch always open or not activated during test
75
Brake on/off switch always closed or circuit shorted
76
No MAF (VAF) change in "goose test"
77
Operator did not do "goose test"
79
Neutral drive switch (NDS) or A/C input signal interrupted
81
Thermactor air bypass (TAB) circuit fault
82
Thermactor air diverter (TAD) circuit fault
83
EGR control (EGRC) circuit fault
84
EGR vent (EGRV) circuit fault
85
Canister purge (CANP) circuit fault
86
WOT A/C cut-off circuit fault (all 3.8L and 5.0L Continental)
87
Fuel pump circuit fault
88
Throttle kicker circuit fault (5.0L)
89
Check Continuity Of VPWR Circuit
91
Right EGO always lean
92
Right EGO always rich
93
Right EGO cool down occurred
94
Right secondary air inoperative
95
Right air always upstream
96
Right air always not bypassed
97
RPM drop (with fuel lean) but right EGO rich
98
RPM drop (with fuel rich) but right EGO lean
99
ECA has not stored enough information to control idle speed (CFI engines only
** On 1986 and later vehicles, this represents RPM too high/low or throttle pedal was depressed during KOER Self-Test
*** Low flow of unmetered air on 1987-88 1.9L EFI engine
[IMG]local://upfiles/9061/BD962512875247D49BBBF9E42922813C.gif[/IMG]
Ford
11
System "pass"
12
13
14
15
ROM test failed
16
17
18
No tach
19
21
ECT out of range
22
MAP out of range
23
TPS out of range
24
ACT out of range
25
26
28
31
EVP out of limits
32
EGR not controlling
33
34
No EGR flow
35
36
37
41
System always lean
42
System always rich
43
44
45
Air always upstream
46
47
48
51
ECT input too high
52
53
TPS input too high
54
55
56
58
59
61
ECT input too low
62
63
TPS input too low
64
65
66
67
68
69
72
73
74
75
76
77
79
81
82
83
84
85
86
87
88
89
91
92
93
94
95
96
97
98
99
