Clanking, Flopping noise in Right Front tire.
this truck is 12 years old and now i have a clanking flopping noise in the right front. A cylanoid had gone out of it and i changed it. now my uncle says it may be the same thing again. my dad, however, says that it is just the Outlaw II wheels that i have on it. says they cause alot of problems. any advice?
RE: Clanking, Flopping noise in Right Front tire.
If i where you I would put a jack under my locer control arm, lift the wheel and put a pry bar under the wheel if there is any movement replace the ball joints. most likely where your pop is comming from. then have the truck aligned.
