Couple of issue - 2004 F150
I have picked up a new to me2004 supercrew with relativly low miles (36000). I had the truck looked at and was told it needed a left tie rod end and the lower ball joints replaced. Seems like low mileage for that. I also notice when starting from a dead stop and going up a hill there seems to be some sort of vibration noise for a few seconds or 20-30 ft.. Do not know where to start??? Could this be linked to the ball join, I assume very doughtful. The truck does have 285 70 17 Goddyear MT/R, could they be the cause??? Something else, help? Just do not want to further damage anything. Also, truck has a leveling kit and an additional spring in rear.
Thanks for the help
Thanks for the help
RE: Couple of issue - 2004 F150
Can you tell what area of the truck the vibration is coming from? Get the ball joint and tie rod end replaced and have an alignment done.It wouldn't hurt to see if the wheels all still had balancing weights on them.Any of thesecould cause some vibration. The previous ownermay have done some offroading with it that caused the tie rod, balljoint, and loss of wheel weights (if they are missing).
Sounds like you need to put some additive in the rear end. My 2004 5.4L 3V supercrew started doing that at about 45,000 miles and put some friction modifier in it and after driving it a few hundred mile, it stopped. That was about 10,000 miles ago.
blovell
10-05-2006 02:10 AM
