default codes
RE: default codes
Is your CEL "ON", or did you just have code pulled? These codes do not clear automatically when the problem clears. You could clear the codes and drive the vehicle to see if they re-appear. If they do, then I would start looking into the O2 sensors.
P1131=HO2S 11 Indicates Lean
P1152 = Lack Of HO2S-21 Switch Indicates Rich
P0171 = System too Lean (Bank 1)
P0174 = System too Lean (Bank 2)
P0175 = System too Rich (Bank 2)
