F150 Powersteering pump removal
Old 05-05-2007 | 10:12 PM
Bruce Lee's Avatar
Default F150 Powersteering pump removal
Iam working on a 1990 F150,6cyl. manual shift 2 wheel drive.I need to relace the powersteering pump,but not sure how to remove the pulley,Can anyone help?
Old 05-06-2007 | 12:38 AM
Default RE: F150 Powersteering pump removal
The pulley has a 'groove' cut into the pulleys hub.. There are a few different types/styles of pullers available to take it loose, but the one pictured is the more common tool, and takes the least amount of room to use and is a 'positive' fit.. Generally their a fairly tight press fit.. You take the 2 'split halves' and put them over/in the the groove with the threaded hub installed, then the round thin collar slips over the 2 halves with the screw shaft portion outwards to apply the pressure making it a solid one piece puller..
[IMG]local://upfiles/6756/417011D14D8D461E8DD240F4C693A0FE.jpg[/IMG]
givemeahollar
03-30-2011 04:45 PM
ryoung
07-13-2009 11:36 AM
jay42782
07-31-2008 01:24 AM
supersix
09-05-2006 06:54 AM
supersix
09-05-2006 02:26 AM
