F150 vibrating when decelerating and braking
![Default](/forum/images/icons/icon1.gif)
I am having a vibration problem with my truck when braking or decelerating from speeds over 25 it shakes the truck horribly I brought it into Ntb and untop of several things the most likely cause was my passenger upper control arm I have changed that on top of several other things I will list at the bottom any help on this issue would be greatly appreciated thanks again
2001 Ford F-150 Larit 5.4 v8 4x4 vin:L
Parts changed:
Passenger upper control arm
Passenger inner and outter tie rods
Brakes and rotors
Both front hub assembly’s
Driver cv axel
Brake booster and master cylinder
All shocks
All new tires
Idler arm
Parts changed:
Brakes and rotors
Driver cv axel
All shocks
All new tires
Idler arm
I don’t feel it in the brake pedal or the steering wheel but it is definitely shaking the body it shook the muffler so bad that it knocked the weight in the middle off
No it isn’t related to hitting a bump and I don’t have to slow down to make it stop it happens when I am decelerating or braking it helped a little bit if I press the gas and Rev it up in between pressing the break pedal
