fast idol stays on
Old 04-15-2007 | 11:55 PM
calvins65's Avatar
Default fast idol stays on
Hi, new to the forum Ihave a 1992 f-150 5.0 the fast idol will not kick down and it runs rich burning lots of gas.I ran the code reader and nothing comes up. anybody got any ideas of the problem?
Old 04-16-2007 | 11:59 AM
Bullitt94's Avatar
Default RE: fast idol stays on
It sounds like the electric choke is stuck. Try spraying some carb cleaner into your trottle body to see if it frees anything up.
Old 04-18-2007 | 11:58 AM
flemingcaleb's Avatar
I had the same problem with my 1995 Jeep Cherokee, it would idle really fast. It wound up being a series of things with that vehicle, but essentially a thermostat on the engine was out.
THEN AGAIN on my 99 f150, that was the throttle pressure sensor - replaced it and bam, problem solved. Easy Fix too. Best of luck my friend.
Old 04-21-2007 | 12:14 AM
calvins65's Avatar
problem solved. it was the plenum gasket. thanks for the replies!
livingstonroofsinc
05-31-2012 06:59 AM
goatpimp
03-28-2010 12:28 PM
joshuathomason
12-15-2009 08:24 AM
DARIN J
07-17-2009 04:35 PM
whatxupxbra
07-05-2007 10:39 PM
Quick Reply: fast idol stays on
