Fouling sparkplugs
Fouling sparkplugs
1997 F-150, 4.6L V8, keep fouling #3, #4, not oil, CHECK ENGINE LIGHT, code PO156, 02 sensor circuit malfunction (bank 2 sensor2), have replaced down stream 02 sensor and cats. NEED HELP PLEASE!!!!
Here are some common causes for a P0156 code.
1. Pinched, shorted, and corroded wiring and pins
2. Crossed sensor wires
3. Exhaust leaks
4. Contaminated or damaged sensor
5. Bad PCM
Also, how did you check your injectors to see if they were leaking or not?
3. Exhaust leaks
5. Bad PCM
