grinding noise
Old 07-28-2008 | 07:54 PM
1rocktoy's Avatar
Default grinding noise
2007 f150 extended cab 4x4.grinding noise not all the time sounds like 4 wheel drive trying to engage.stops only when you slow down then makes a bang from front end.ant ideas?
Old 07-29-2008 | 10:48 AM
2002F1502WD's Avatar
Default RE: grinding noise
return to the dealer and have it checked out befor you attempt to fixthis issue. This truck should still be under warrenty.
Old 07-29-2008 | 07:41 PM
1rocktoy's Avatar
i realize its under warranty,was just looking to see if anybody had the same problem.noise is getting more fequent.made a appointment for thursday see what they find.
Old 07-29-2008 | 08:46 PM
hey man sorry if i came off ignorant in my previous post. The fords are bad about dirr and transfer case issues most likely the grinding is comming from bad bearing in the front diff.
Old 08-01-2008 | 06:33 AM
1rocktoy's Avatar
got my truck back from the dealer.was the vaccum actuator for the 4 wheel drive shorted internally.
Nrod
08-30-2016 03:16 PM
miwanicki
01-19-2008 03:27 AM
mofeekin
08-27-2007 01:09 PM
karen travers
12-20-2005 05:16 PM
spydr71
11-28-2005 01:46 AM
