Help troubleshooting driverside front end issue
I have a 04 ford f-150 4x4. I have noticed a noise in the front end that sounds like you have a bad tire. I have replaced al four tires and still of the noise. I am trying to narrow it down but have run out of ideas as to what it could be. There is no more than normal play in setering wheel. The noise gets louder when I turn the wheel to the left. Any ideas would be greatly apperciated!
If the sound is a roaring noise that sounds like a chopped tire and gets louder when you turn i think you are a victom of a bad wheel bearing. When a wheel bearing goes out you get a grinding or humming noise witch will increase or decrease while turing to the opposing side. Jack the truck up and leave in N put it is 2 wheel drive and spin the wheel and listen for a roar.. Also could be a bad CV joint. The joint soes not have to be leaking grease or have to grease to cause a noise.
digital_diversion
06-20-2013 09:10 PM
Nick Greenfield
04-18-2013 04:39 AM
QuickSilver
07-14-2009 04:18 AM
