high rpms no power in first
Old 07-25-2013 | 09:31 PM
Doug Moore's Avatar
Default high rpms no power in first
I have a 90 f150 4x4 5.8l. e4od. to get it to move in first gear it revs up then moves real slow then it will shift fine until I stop. then it does it all over again. if I manually shift in first no problems. fluid is full and clean new neutral switch and harness. what else could it be?
Old 07-26-2013 | 10:18 PM
greasemark's Avatar
So. If I'm reading this correctly, it's starting off in some other gear then first? If so, check the connections all over the trans; the sensors may have a connection problem, however, that would usually trip a CEL.
Old 07-27-2013 | 12:04 PM
Did you notice if the OD light on the shift lever was on or flashing?
Monk
11-10-2018 07:51 AM
vaultdweller
08-12-2017 04:15 AM
surferjoegomango57
12-11-2013 03:32 PM
robnkim
03-12-2013 01:42 AM
Anthony Baron
10-29-2012 02:43 PM
