Instrument lights/ neutral safety switch/ turning sounds
Old 05-26-2011 | 11:57 AM
powerstrokecrawford's Avatar
Default Instrument lights/ neutral safety switch/ turning sounds
Okay, first of all, their are a few problems with my truck yet it is still drivable. I drive it daily. Okay so first off, my instrument lights will not come on, the only thing I have checked for is the fuse and it's still good.
My second problem is that I can only start my truck in neutral and I don't know how how to adjust it at all unless its off the piece that is connected to the transmission. I replaced the transmission myself and it works great, just have to park it in neutral.
And lastly, when i turn my truck, my truck seems to make this grinding noise but its electrical...idk, but if yall couold please help me, itd be much appreciated, thank you.
I have a 1993 F-150 with a 5.8L. Ext. cab short bed.
Old 05-27-2011 | 11:42 AM
Welcome to the site..
So,, none of the instrument panel lights work.. Turns, illumination, warning, anything? In most cases when the truck will start in neutral only, the transmission range sensor (neutral safety switch) on the side of the trans needs to be adjusted or replaced.. Is the shift lever 'solid' meaning no excessive play?
To check the adjustment on the range sensor, there are 2 scribe marks on the face of the sensor. One on the sensor body, and the other on the rotating center. With it in neutral, the lines should align.. If they don't, loosen the 2 bolts and adjust prior to a replacement. Could be a connector issue too if the sensor plug is removed and you see corrosion.
Does the starter just spin, or grind, or just click at times?
faof2
10-21-2014 05:31 PM
Gregjg
12-01-2012 02:10 PM
Mr. Din
08-22-2011 05:53 PM
88nate
05-18-2011 09:42 PM
rlevy64614
09-25-2008 10:13 PM
