intalling alarm can't get doors to lock/unlock
Old 03-30-2010 | 07:24 PM
rosebud12's Avatar
Default intalling alarm can't get doors to lock/unlock
I'm installing a commando model RS-560 alram system on my 95 f-150, and the door's will not lock/unlock using the remote keyless entery. however they will work using the door swicth. The alarm system requires 2 5 pin relays and also has a 3 pin door lock connector with blue and green wire( blue unlock/green lock). i have connected the relays and the 3 pin connector as stated in the installation manual, but it still will not work. dose a 95 f-150 have a positive or negative door pins? I have the system set up now for a positive door pin reading from the driver door switch and common wire running to the passanger door switch. Can any one help me please i'm about to give up?
gatorvette
12-31-2013 02:55 PM
/m3
11-29-2013 11:48 AM
MWenckowski
11-21-2011 07:28 PM
Ford1st
03-26-2011 03:13 PM
DeanoNC
01-06-2006 02:03 AM
Quick Reply: intalling alarm can't get doors to lock/unlock
