my o3 wont start any ideas?
Old 12-07-2010 | 06:58 PM
steck1's Avatar
Default my o3 wont start any ideas?
my 5.4 cranks over but wont start. today it started then sputtered and shut off. then it started and ran fine til i got home i shut it off went to start it and it just cranks. this only happens once in a while, no check engine light is on, whats the problem?
Old 12-07-2010 | 07:43 PM
hihosilver's Avatar
Have 2002 Mustang, same problem. Hardest thing to find is straight answers. Some on-line helpful hints are are flat out lies and what appears to be misleading information.
The same basics apply. Have spark and gas, assuming timing is on, engine should start.
If no start, check Schrader valve for fuel pressure on fuel rails connecting to injectors. Looks like a tire valve. Place absorbent rag or paper towel at Schrader valve. Depress valve like letting air out of tire, gas should shoot out at about 40 psi. No gas, no fuel pump action. That can be for several reasons. Turn ignition key to run, fuel pump should run for 1-2 seconds the click to stop. Check fuses in engine area fuse box. Check Fuel Pump Driver Module supplies variable voltage to fuel pump. Check fuel pump. All are expensive items. Ford has managed to make a simple fuel delivery system very complicated. If you have fault codes,good. Last, take it to Ford dealer for repair.
Old 12-07-2010 | 07:49 PM
hihosilver's Avatar
Check collision switch usually in trunk, next to left tail light. If popped, depress/reset red plunger button.
Old 12-07-2010 | 07:57 PM
steck1's Avatar
Default its a 150 pickup
someone told me it could be the chip in the key went bad but i changed keys and it didnt work. but ido hear the fuel pump workin and i just wnt out and it started right up. this did this about a month ago and started right up everyday except for today. could it be a coil pack going bad? i had one go bad on my 99 1 time it started and just ran like **** so im at a loss????????
TheBurd
02-19-2008 03:46 AM
squad272
04-22-2007 02:01 AM
drw0392
10-13-2005 12:26 AM
shimellle
09-18-2005 12:55 PM
