Need A/C Help
Old 06-29-2011 | 09:31 PM
GRANTOU812's Avatar
Default Need A/C Help
I have a 2001 Ford F150 with 5.4 V8. The A/C quit this am. I added a can of freon this evening. When I start the truck, the compressor kicks on for about 20 seconds or so and then stops. Ocassionally it will kick back in for a few seconds and then stop again. I can feel the line beginning to cool, but then the clutch disengages. I tried a jumper wire in the high pressure switch and no change. It got dark on me and I did not get to try the low pressure switch (I believe it is on top of the evaporator canister). Any ideas...or anyone else ever seen this problem?
Old 06-30-2011 | 12:01 AM
Along with making sure there's a correct fill, and checking voltage through the cycle/pressure switches/connectors, make sure the air gap on the clutch is within specs.. To wide and the clutch has trouble pulling to a lock. If you loose current to the cycling switch, check power distribution..
Old 07-02-2011 | 04:30 PM
GRANTOU812's Avatar
Thanks. The air gap is greater than .033. It only has one shim in it, If I remove the one shim the air gap is less than .014. Do you think I should replace the entire clutch assembly?
Old 07-02-2011 | 09:49 PM
GRANTOU812's Avatar
I rechecked the voltage at the compressor and after 15 - 20 seconds it stops. That is why the compressor stops. If you restart the truck it has power to the compressor again but for only 15 - 20 seconds. Any Ideas?
Old 07-16-2011 | 02:47 PM
RonaldD's Avatar
I hope you meant R134. I haven't heard you mention gauges. If you don't have enough R134 in it the low side pressure will get too low and the compressor will kick off.
jd637
02-22-2019 09:14 AM
jborushko
12-22-2016 09:06 PM
BigRig Mechanic
02-26-2009 07:12 PM
streetbob
06-17-2008 06:01 PM
Adhd
02-03-2008 10:55 PM
