New F-150 owner
Old 12-13-2004 | 04:16 AM
yawgom's Avatar
Default New F-150 owner
I've just bought a F-150 FX4, it barely have 100 miles on it, but I feel the truck a little slow, and mostly after driving a Dodge Ram Hemi, I dont think that the extra 45 Hp of the Hemi could make that difference on the end. I would really apreciate if someone knew how to make it a little more awake or could tell me where the 300 Hp of my engine are....
Old 12-14-2004 | 12:32 AM
yawgom's Avatar
Default RE: New F-150 owner
Here is a picture of my truck...
Old 12-14-2004 | 02:44 AM
94Flare's Avatar
You could start with simple things if you want to see more power from your truck. K&N Cold air intake system and filter, recalibration of the ECU (Computer), and exhaust change can make a world of difference and are not real costly, however they will reduce puel economy. If you want to go even futher there are a lot fo good supercharger set ups that run under $5000 and some that are even under $3000. And last but not least, check out the link to the website I have attached. It will take you to ZEX's website and they have a wonderful little simple bolt-on nitrous sytem that installs easily and is simple to set up.
www.zex.com
Old 12-14-2004 | 04:16 AM
yawgom's Avatar
Thanks for the advice, I think Ill try the K&N system and the computer, about the exhaust I dont want anything noisy, so I think is better that way...
Old 01-31-2005 | 02:50 PM
PureCracker182's Avatar
Hey man whats up? I have some questions for you. I am actually looking at a truck that is identical to yours and i was wondering how you liked it. I know you said in this post that it is slow but thats not an issue. How do you like the FX4 package and how does it do with towing and just normal driving. Thank you. Anyone else that has the same truck feel free to post. Thanks again.
Brian
Old 04-22-2005 | 06:31 PM
yawgom's Avatar
The drive is smooth, and the 4 by 4 capabilities are endless, yesterday I went up in a 50 to 60 degree angle in soft dirt, in 4 Hi, then when I felt it a little overstressed, I turned the switch to 4 Lo, and then the problem was over, it really have serious Off Road capabilities. And maybe the lack of power of the truck was because the engine was new, in these last days I have noticed a little more power, and other factor is that the speed in a truck does not feel like in a car.
Old 04-22-2005 | 06:36 PM
yawgom's Avatar
Oh, and about the towing factor, it is great, for big loads, you have to turn on the 4 Hi at least, and if you feel that you need some power you can turn on the 4 Lo, (great thing that is an electronical shifter) the con on the 4 Lo is that te top speed is about 50 - 60 MPH, at 4,500 RPM (out of 5000).
Old 04-25-2005 | 05:02 PM
cctxfish's Avatar
Yawgom
the attachment looks like the truck is in Mexico [8D]
Plus the 'LOBO' emblem
You from there?
Old 06-02-2005 | 05:57 AM
yawgom's Avatar
Yep Im from Mexico.
Old 06-03-2005 | 01:01 AM
Tempestv's Avatar
ORIGINAL: yawgom
Just how big is a "big load"?
Quick Reply: New F-150 owner
