No sound from radio
Old 12-18-2008 | 01:04 PM
marylou's Avatar
Default No sound from radio
I have a 1997 F150 extended cab, whichhad to have the heater coil replaced. Ever since then, there's no sound coming from the radio. It appears that everything was hooked back up correctly, and all the lights on the radio work. If you push the volume +/- it appears to work, just no sound. This is the original radio with original CD changer located in the back seat (ESC with CD DJ). I've heard people talk about an unlock code, but not sure that's what I need since it appears to work, just doesn't produce sound. Any suggestions? Thanks!
Old 12-18-2008 | 07:07 PM
way2old's Avatar
Default RE: No sound from radio
Have you removed the unit to see if all wires are connected? It is possible the person doing the work left some wires unplugged. Did you take it back to have them look at it?
Old 12-19-2008 | 08:00 AM
marylou's Avatar
Yes, we'vetaken it out and all the wires appear to be hooked up correctly.
gerridawn
10-19-2013 06:09 PM
badgolf
02-24-2012 11:21 AM
notsosmooth
01-11-2012 09:20 PM
b3n129
09-20-2008 06:59 AM
sniper
07-21-2005 04:23 AM
Quick Reply: No sound from radio
