No Turn signals pls help
I have a 96 f150 4.9 and I have no turn signals I have tried everything from replaces fuses, tracing down all the wiring, changing bulbs, changing relays and replacing the multi signal switch in the dash and nothing I have tail lights, brake lights and running lights but no turn signals, also there is no tick or turn signal indicators on the dash, any information would be extremely helpful!!
There is usually a turn signal flasher mounted at the under dash fuse panel. Some had the flasher hidden behind the dash to the right of the steering column.
Some had a 2 prong flasher and some used a 3 prong flasher and some used an electronic flasher.with 5 prongs.
My guess is the turn signal flasher is bad. It is worth a try as they are inexpensive. The owner's manual will help. Page 355 in the owner's manual..
https://www.fordservicecontent.com/F.../96f12og1e.pdf
They usually are not interchangable. Hazards have two terminals and turn signal have three terminals.
