NSS wiring help
Old 01-19-2007 | 11:54 PM
yonu's Avatar
Default NSS wiring help
Hi,
I am hopeing you folks can help me out I swapped a motor and AOD trans from a 88 grand marquis into my 79 F100 I am trying to finish up the wiring and have a minor problem I was able to wire the backup lights with no troublew but I have no idea how to wire the NSS as it only has 1 wire so I am a bit confused what to do with it any help would be great
Thanks in advance,
Yonu
Old 01-20-2007 | 12:45 AM
wheelsup68's Avatar
Default RE: NSS wiring help
Gery Rig it, remove your old NSS and plug in to trucks harness and fix it so it is engaged. Then just remember to not start it in drive.
Old 01-20-2007 | 12:48 AM
yonu's Avatar
It is kind of like that now however I am trying to get it wired like it is suppose to be
thanks,
Yonu
Old 01-20-2007 | 01:49 AM
mayday's Avatar
Is this simply a wirethat closes a loop when grounded? If so, you might be able to add a BOO like switch to your brake pedal. Put it ahead of the pedal instead of behind with a bracket. Then the truck will only start once you press the brake. It's not for me to ask why all the trouble.
'major' on www.feoa.com
Old 01-20-2007 | 01:56 AM
yonu's Avatar
there are 2 reason well actually 3. One is that I like everything to work, second is once in awhile I will loan the truck to a friend to run errands and want to avoid any mishaps and the 3rd is I installed a remote starter but have yeat to hook up the last wire for the fear of it not toally being in park and off it will go when I hit the remote, and as to the question about a loop I am not sure there are 3 wire on the plug on is the power coming in for the backup lights one is the out going and the 3rd I would assume is the NSS but I have no Idea how to make it work with 1 Wire
andy1865
10-11-2010 12:12 PM
chemoman
03-17-2008 03:05 PM
turbo79
04-23-2007 01:56 AM
tomt81
04-27-2006 01:43 AM
tomt81
11-02-2005 03:31 PM
