Offroad lights and light bars | CARiD
No Off Road vehicle is complete until you have Off-Road Lights! It's a must have for any off-road enthusiast. Off road lights let you hit the trail safely in the nasty weather or cover of night. With heavy-duty casings and materials, these off road lights help blaze a trail through the mud and mess.
Unlike factory vehicle lighting, off-road lights can be pivoted in any direction you choose to see down a sudden drop off, to the sides to see around switchbacks, or when you need to look up from a dip.
A strong lighting source from a high location allows you to make better decisions on the trails. Quality off-road lights should have lightweight composite construction so things don’t shift out of position or vibrate loose when bouncing around on the road. Higher-end lights offer the ability to focus and adjust the light beam for a wide spread or targeting one specific area with the intensity of a laser beam.
Whether you want to set up off-road lights on your roof, front bumper, rear, or other areas, we have them for you. Here is the list of several interesting options:
Lumen® - 51 Watt LED Round Off-Road Driving Light mounts easily on any pre-drilled holes atop headache racks, bull bars, or grille guards. Total LED power: 51 watts from 17 radially mounted pencil beam LEDs.
KC HiLiTES® - Apollo Lights have 6" Round Slim Housings fitted with 55W or 100W Halogen Bulbs.
ARB® - Intensity LED Light are equipped with 90 Watts bulbs, have amp draw 6.25A @ 14.4V, 32 LEDs, 8200 raw Lumens.
KC HiLiTES® - Pro Sport HID Lights have 6" or 8" Round Black Composite Polymax Housing and Super Bright 35W HID Bulb.
For all Off-Road lights we carry click here: Off-Road Lights for Trucks & SUVs at CARiD.com
Whether you're building a serious Baja racer or just want your truck to look suitable, another type of lights is definitely worth your attention – the Light bar. LED bars can accommodate round or rectangular rally style lights. Let's take a look at few options we carry:
Smittybilt® - RPD Light Bar includes 3 light mounting tabs for lights up to 9" in diameter, manufactured from 1.5" diameter 0.120" wall thickness steel tubing.
Smittybilt® - Street Light Bar includes 4 light mounting tabs that can accommodate up to a 9" diameter light, manufactured from 1.25" diameter 0.095" wall thickness steel tubing and have a high-gloss powdercoated finish.
Read more about Smittybilt at CARiD: https://www.carid.com/smittybilt/
CARR® - Deluxe Light Bar holds up to 4 lbs of weight, have 7 pre-drilled holes for auxiliary lights and available in stylish XP4 Titanium Silver, XP3 Black, and XM3 Polished finishes.
Which one do you prefer?
I have a question. If my truck roof measures 52" from let to right why are most people using 50" led bars? Are they measured from the light section only? Or is the dimensions including the end(caps) Thanks,
Craig
Craig
Thank you for the information. So relatively speaking I could purchase a 52" inch bar as well? Since it sits on the roof line is can and do they whistle as the air moves over them? Sorry for all the questions, I just want to make sure it is right for me.
4DirtyTires, any lights bar can make a whistle sound, very mild that you can hear only on the really high speeds. But I believe that if you consider purchasing a light bar, whistling sounds is just something you need to accept.
Make sure you are driving safe at night! Improve the style of your car and save 5% on all Lumen LED lights. Appy this CODE now: LUM-5OFF-DISC
Check all Lumen products here: Lumen® LED Bulbs, Off-Road Lights, LED Bars at CARiD.com
carid
11-27-2014 06:06 AM
Jayh524
12-16-2013 05:49 AM
