P2135 Electronic Throttle Body Replacement
Throttle body failures on the 5.4L 3v are more common than you think, luckily it will pop a code for the throttle body more often than not helping with diagnosis. Symptoms include start and dies, no start, a really rough idle, surging idle up and down more so in park, poor brake assist due to rpm fluctuation and wrench light on. If you find yourself in this situation I show you how to change the throttle body and reset the pcm to learn the new idle trims.
makuloco2000
11-06-2014 02:36 PM
WV-F150-4.2L
03-16-2011 06:34 PM
