Popping Noise in Front End?
Old 07-21-2007 | 01:28 AM
harr6607's Avatar
Default Popping Noise in Front End?
Ok, so I have a 2005 model 4x4 that was having this popping noise in the front end whenever i would come to a stop and then go to accelerate again. The dealership took the drive shaft apart and found metal flaking- they recommended replacing the drive shaft , but being broke as i am, i just had them clean the flaking and put a tube of grease in there. I drove it around a bit this afternoon and let that grease work in there and it seems to have solved my problem,-- but i'm not sure how long this will last. Is it really necessary to replace the entire drive shaft or can i just have them replace a faulty component of the drive shaft- or does it work that way at all?
Old 08-01-2007 | 09:27 PM
SpawnsFate's Avatar
Default RE: Popping Noise in Front End?
I would get a second opinion on that. I had one a while back, and if it is the sound that I am thinking of. It was coming from the pinion gear in the diff.
Old 08-11-2007 | 10:40 PM
02greenF150's Avatar
Drive shafts are balanced and they should be replaced as a whole unit, u-joints are a different story , you can replace the joint and not cause balencing issues although the yokes shoule stay whith the banenced shaft. I agree with SpawnsFate check the pinion gear. I rebuild a lot of them even though it is only a 2005.
bent-sideways
12-27-2010 01:13 AM
03expyeb
02-02-2008 05:23 PM
Higgy1982
04-26-2007 02:34 AM
texasquail
01-29-2007 01:17 AM
mad man
01-04-2006 04:17 PM
