power door lock fix
Old 12-24-2006 | 12:02 PM
chriscb's Avatar
Default power door lock fix
OK here goes....2001 F-150 Crew....all's well except no power lock function at all. Not from drivers side master, nor at each door. Have looked thru owner's book, but don't see a fuse designated as such. Suggestions? Next issue...Frontpass windowdropped out of sight yesterday AM (28 F). Tore door apart, replaced glass in two bottom tracks, but am hesitant to lower it 'tilafter the Holidays...(where's global warming when you need it). I suspect the great Ford seal at the window top will overcome the gooey mystery material that anchors glass in tracks. Next time I want to fix it to stay.I considered super glue but rejected that as too inflexible. Is there an alternative. Thanks.
Old 12-24-2006 | 04:28 PM
Capt.Moe's Avatar
Default RE: power door lock fix
Do you still have factory waranty with it? I guess not that why you are comming here, okay as for the door locks sounds like the solenoid might be shot, and as for the window, that's sad to hear that happen, but it's cheap made china-products that ford is using for this kind of stuff now, so expect that it will do it again, and again, untill you have the hole assembly replaced, it's a shame too hear that you are having these problems with such a new vehichle, they just don't make them the way they used too anymore. What a shame.
Old 12-24-2006 | 04:37 PM
chriscb's Avatar
Hey Capt Moe, So in addition to understanding all about global warming I need to learn Mandarin to fix my "American Made" truck. Thanks for your reply. CCB
haledonoem412
08-18-2007 05:34 PM
tommyp35
04-05-2007 04:48 PM
moosedrool
02-13-2007 03:00 AM
austin
09-24-2006 11:35 PM
tbryangolfman
01-21-2006 05:12 PM
Quick Reply: power door lock fix
