Problem with 86 f150 starting
Old 09-27-2013 | 11:40 AM
jefcro14's Avatar
Default will do
I'll take a look at this today. I'm having it out today with the state over unemployment. I was a teacher any my position was cut May 24th and I filed then but I still haven't received an unemployment check. This is ridiculous. I've got a wife and two kids.
  #22
Old 09-27-2013 | 07:00 PM
Hope you made some progress with the state.
  #23
Old 09-29-2013 | 11:27 PM
jefcro14's Avatar
Default Follow up
OK, no spark from plug wire noticed. Pulled wire off as requested and placed as stated but when I tried to crank the engine no spark was visible. And no, state was as useless as Senate and House in Washington. Still no approval and no idea when.
  #24
Old 09-30-2013 | 10:42 AM
jefcro14's Avatar
Default Fuel pressure regulator
I took off vacuum tube on regulator and there is not any fuel in the line. It's bone dry.
  #25
Old 09-30-2013 | 06:15 PM
I am going to suggest you check the following site . It spells out each step for checking a no start and you can refer to it as you check each step at your leisure.
www.easy auto diagnostics .com
  #26
Old 09-30-2013 | 06:16 PM
  #27
Old 10-01-2013 | 07:39 AM
jefcro14's Avatar
Default Great how-to site!
Thanks hanky! That website is a great suggestion. I'll let you know what I find out.
Thanks so much!
FL3471
03-09-2013 03:45 AM
caforeman
03-07-2013 07:35 PM
bob walls
03-16-2008 05:42 PM
bob walls
03-16-2008 05:42 PM
arcduncan
01-02-2006 06:56 PM
