problem with fuel injection
Old 07-20-2012 | 10:36 PM
bandit1948's Avatar
Default problem with fuel injection
i have a 1996 ford f-150 302 engine ! it,s burning lean and i have trouble starting it in the morning ! it acts like it,s not getting enough gas for it to start up ! would the fuel regulator cause it not wanting to start after its been sitting a long time? it turns over good but it takes a long while before it will fire up but once it starts it,s okay until it sits awhile then it has trouble starting again ! i changed the plugs, plug wires, cap and rotor and fuel filter ! i am thinking about changing the regulator to find out if that,s the problem ! thanks guys !
Old 07-21-2012 | 08:28 AM
Before you spend anymore $ why not consider trying this ?
When the vehicle has sat a while, turn the ign switch to on ,then off, then on maybe 2-3 times then go to start it. If that corrects the delayed start problem there could be a defective check valve in the fuel pump module that is supposed to prevent fuel drainback to the tank. Let us know if this helps eliminate the problem.
Old 07-21-2012 | 11:23 AM
bandit1948's Avatar
thanks for the input hanky but do you suppose it could be the regulator not holding the pressure up to the injectors ? i am getting a lean burn when it does start ! the tailpipe stays as clean as a brand new one all the time ! i get no hesitation after it starts and it idles good ! if i shut it off it will start right back up but after it sits a long time it will crank a lot before it fires up ! i have duel tanks so i doubt the both fuel pumps would be bad ! i put a new filter on it too so do you think it could be the regulator ! once it starts it will take the gas good and sit and idle good ! thanks hanky !
Old 07-21-2012 | 03:54 PM
Does the hard start happen regardless of which tank you happen to be pulling fuel from?
I don't believe the pressure reg is the problem, but I have been wrong before, lost count.
There may be a problem with the reservoir assy that all fuel from either pump must pass through. If you could get your hands on a fuel pressure gauge it would help to confirm if you really have a fuel problem or something else is going on.
Old 07-21-2012 | 04:54 PM
greasemark's Avatar
Just my two cents: I agree w/Hanky; the lean start is probably happening becuase the fuel pump can't/isn't making the required pressure; they did have the check valve in the tank w/the pump, but it's replaced together.
And even if you suspect the regulator, which is completely possible, you'd have to use a fuel pressure gauge to test it; it probably takes a while to build up.
And even with the gauge connected, you have to plug the return line to see if the pump CAN produce the pressure.
Old 07-22-2012 | 10:35 AM
bandit1948's Avatar
it,s still the same HANKY regardless what tank i am running off of ! do you suppose there is an injector hanging up ? it idles good and no hesitation when you hit the gas ! maybe i should use some good fuel injection cleaner in the tank ? i appreciate all you folks for coming back to me !
Old 07-22-2012 | 10:36 AM
bandit1948's Avatar
hey HANKY ! DO YOU SUPPOSE THE GAS CAP IS NOT HOLDING THE PRESSURE IT NEEDS ?
Old 07-22-2012 | 11:19 AM
Mr bandit1948,
Any pressure in the fuel line system is produced by the fuel pump(s).
Since the problem is present with either tank/pump you are going to be chasing a wild goose without using a pressure gauge to either confirm or rule out a possible fuel problem. There is always the possibility of a non fuel problem so I would again ,suggest get a fuel pressure gauge and check the system properly then you will know for sure where you stand.
67plymouth
12-28-2011 06:12 PM
jcbassmaster
12-22-2006 05:42 PM
JP
06-30-2006 02:11 AM
fordbronco351
04-08-2006 07:38 PM
sideways4m
09-09-2005 08:05 PM
