rought idle no power brakes 2005 f150 4x4
Had a bad flywheel, swapped it out over a week. All went well till I reconnected the battery. rought idle and would die and had no power assess brakes. Tried the owners manual for replacing the battery to no avail. truck ran good before .
You might go over all the work you did and may find a disconnected vacuum line.When we recheck work done , many times things are found that were thought to be done or were not done correctly. We've all been there and that's why we learned to double check everything.
