Setting Timing
Old 08-24-2005 | 09:47 PM
fordmann67's Avatar
Default Setting Timing
Recently I installed a 302 engine ( from a 1990 E-150) into my 1994 F-150 (also orignally had a 302).What do I set the timing at? The radiator support says 10 degrees BTDC, is that what I set it at?
Old 08-24-2005 | 11:45 PM
cctxfish's Avatar
Default RE: Setting Timing
For me this really doesn't matter. If 10' feels, sounds, and is giving good preformance, then its good. Now you can go ahead and move it more advanced say 5' incraments, until it start pinging. Then back off a little, that should give you good performance. If you start having idle problems, like you have to idle at 800+ to keep it running. Then you need to back it off a little more until you get the best of both worlds, good upper end, and idle.
Old 08-27-2005 | 03:03 PM
hockeyhitman69's Avatar
yes some at 8 and some up to 12 it is a preference where you find it works best
andy1865
09-30-2013 11:59 AM
Biscuit
11-01-2010 04:52 PM
alignmatt
05-03-2007 02:03 AM
Doyle
09-25-2005 07:32 PM
frack
08-01-2005 07:55 PM
