Smoke Problem
Smoke Problem
I have a 1990 Ford F-150 5.0 4x4 Automatic. The truck has 120,00 mile and is a great truck. My problem is as I go down the highway with the cruise control on the truck will suddenly start smoking, not out of the exhaust but from somewhere under the truck. I replace the dome cover gaskets. I checked the rear main, and cannot find the problem. Someone told me to replace the pcv valve. When I did the problem got worse. Can the egr valve be causing the problem. I have had people follow me and it definetly smoke from under the truck and not the exhaust. I would appreciate hearing from anyone who might be able to tell me what to do next.
Thank you
Lou
Thank you
Lou
RE: Smoke Problem
Lou,
You got me on this one. I have never heard of anything like it.
Is there anybody have any ideas.
I'd think you have an oil leak somewhere leak something on the exhaust converter cause you problem, but it would have nothing to do with the cuirse control. The cuirse control only has a few components, the control switches, speed sensor, amplifier, servo and vac dump valve, non of which I think could cause this problem. I guess I'd first try looking into any vacuum hose miswireing
RE: Smoke Problem
What engine are you running? If it is a V8 check leaks around the valve cover gaskets. If they are leaking on the exhaust manifold, you will notice smoke under the vehicle. You will also smell oil burning. On older Fords that was open to the atmosphere, this was a common thing whenever the engine was being starved for air. Not too sure about these new computerised systems that are completely closed. Old mechanics don't die, they just forget who they are. Carl
RE: Smoke Problem
Please don't take this as an offense.. When you say the leak was at the end of the intake, do you mean the Intake Manifold Gasket? If so, what you were expereriencing was not an oil leak, but a water leak. I suspect. Yes, a high pressure water leak would look like smoke, but you would also experience a loss of water which would make the engine run hotter than normal. Carl
RE: Smoke Problem
Well....I am gonna take a stab at this one. BLOWBY! And the only reason I am thinking this is becasue the fix that I would have suggested (replace the PCV valve) caused more issue than reliefe. My guess is that the valve stems are pretty worn for the number of miles, and that your engine is actually building pressure under the valve covers and it is being forced out of any place it can find. On the old carburated engines you could pull the air cleaner cover off and soak up a quart of oil if the blowby was bad enough. Solution...valve job with new valve guide inserts, or make sure that they get re-knurlized before they are bolted back together.
carid
08-12-2015 06:02 AM
mdbuffy
10-08-2005 08:02 PM
