still trying 92 F150
#12
I would like to know what would stop the injectors from working any thing from not enough pressure to the control box because as I stated before it tries to start when I floor it and spray ether in through plennum
#16
Need you to try two things.
Remove the coil wire from the cap place it 1/4 in from engine ground and crank the engine. you should see the spark jumping as the engine cranks. Do you see any spark?
