Strange noise
Old 04-15-2007 | 01:36 PM
kerwinq's Avatar
Default Strange noise
My truck has been making a high pitched noise from inside the cab when first started, it goes away once it has warmed up. It sounds like it is coming from the speakers like you would get from bad plugs that don't have a noise filter. I replaced the plugs some time ago and this is a recent issue. The noise seems to go up and down with the speed, so when starting out it gets louder until the trans shifts then gets quieter. Once it warms up(after about 10 min) the noise goes away, and it seems to only happen when the temp outside is below 35, so does not happen during the day or when I leave work in the evening
Is there some sort of a noise filter that can be changed?
Thanks, Kerwin
Old 04-16-2007 | 12:02 PM
Bullitt94's Avatar
Default RE: Strange noise
Do you have an aftermarket stereo? If you do, sometimes the location of the wiring will pick-up engine noise.
Old 04-16-2007 | 12:09 PM
kerwinq's Avatar
I do have an aftermarket stereo, but have had the truck for about a year and have not had the problem until the last few days. Nothing has been done that would have affected where thewiring is at under the dash or engine bay. The funny thing is the noise goes away once the truck warms up and seems to be there whether the radio is on or not, or if the heater is on. Just seems very odd that the noise would go away once it warmed up
Mezcalwest
06-04-2008 02:53 PM
wanggoudan
08-17-2007 04:54 PM
offroad1
07-27-2007 10:12 AM
Rikymaru
01-26-2007 10:52 PM
lucasleigh
01-25-2007 03:28 AM
