Stuttering 4.6 driving me crazy
Old 12-12-2006 | 11:09 PM
brittainmcneil's Avatar
Default Stuttering 4.6 driving me crazy
Ok, so my truck has been stuttering for a while the check engine light comes on and it's either bank 1 too lean or cylinder 1 missfire. It's a 1998 4.6L with 113,000 miles. I have replaced the Plugs, wires, and PVC valve @90,000 (no problem after replacement), coil packs, and oxygen sensors within the last week. I have cleaned the Idle air control valve, cleaned the TB, and cleaned the MAF Sensor (with the plastic safe sensitive electronic QD cleaner). Only thing I haven't done is replace or clean the EGR valve. Any ideas? I'm starting to get really frustrated and might have to give in and take it to my Ford dealer. Thanks,
Brittain
Old 12-13-2006 | 11:32 AM
Bullitt94's Avatar
Default RE: Stuttering 4.6 driving me crazy
Did you try running some fuel injector cleaner with your gas?
Old 12-29-2006 | 02:56 AM
Echo77's Avatar
my other truck had this problem stuttering during traffic, supposedly quick lube never changed my Fuel filter and the intank fuel pump couldn't handle it anymore and finally died, but i did the exact same thing everyone was saying, check your maf sensors, your pvc vavles, your intakes, run fuel injector cleaner,your blah bl blah bl blah.... the whole time it was the fuel pump going out. theres no way to tell if your fuel pump goes out til it does.
mac1
06-21-2014 09:23 AM
Kiley8955
04-12-2012 06:36 PM
charles_tint
08-07-2008 10:39 PM
RealFnCool
06-13-2008 10:08 PM
estraw
06-30-2006 07:21 PM
