Thermostat
Old 06-15-2019 | 11:14 PM
Scotty Vanderpool's Avatar
Default Thermostat
I have a 1997 f150 with the 4.6 . I was changing my thermostat and everything was going good in till I started putting the bolts back in to the housing . The bolt goes back in but won't screw in . It's like there is no threads there . Anyways if anybody has any advice I would greatly appreciate it.
Old 06-16-2019 | 08:00 AM
Have you owned the vehicle since new?
The reason I ask is , we don't know if someone else messed up the threads or not.
You have a few choices though.
You could install a Heli-coil ,
There are some pretty good thread making compounds on the market,
If the threads are all gone and you have enough meat to thread a slightly larger hole with the next size bolt,
Are you sure the hole has no threads left? Could there be a problem with the bolt?
Old 06-18-2019 | 06:00 AM
The threads was all gone . I had to retread it with a bigger bolt . Thanks for the advice .
RMP6500
09-15-2018 08:39 PM
jdshivers0613
12-10-2016 10:42 AM
dover6811
02-21-2015 09:46 PM
iuecbrad
11-15-2012 06:57 PM
1994 F-150 5.0 2wd
06-13-2009 02:45 PM
