Thought it had to be the VSS
Old 03-07-2013 | 01:12 AM
EFOSTER's Avatar
Default Thought it had to be the VSS
I have a 95 f150 4 wheel drive. All was good until I started it this morning and the odometer didn't work, the speedometer didn't work, the od light is on, the abs light is on, and the transmission isn't shifting right. I figured it had to be the VSS so I replaced it (on the top of the rear end) and its still doing the same thing. Is there another sensor that it could be? I'm completely lost. The fact that it happened all of a sudden seems strange but I'm hoping somebody can help me out.
Old 03-07-2013 | 04:16 AM
On the trans should be two or three plugs. Two on the driver's side an one on the passenger side. carefully remove each one and check for any green corrosion. If you find any you can flush both parts of the plug with a good penetrating oil to clean the plug and pins. On the driver's side at the tailshaft housing should be the speed sensor.If you remove that and check it for generating an AC voltage (very low) when spun you should get something. If not , the sensor is defective.
It is important to check all the things listed !!
Old 03-07-2013 | 01:19 PM
EFOSTER's Avatar
Thanks. I'll try that and see if it fixes the problem. Could any of these be sending a funky signal that causes an misfire at all?
Old 03-07-2013 | 01:28 PM
I don't think so, but with electronics some strange are capable of taking place.
Just for starters,
when was the last time you replaced the spark plugs? Ford vehicles DO work better with Motorcraft plugs.
Old 03-07-2013 | 04:23 PM
EFOSTER's Avatar
Just for starters,
Changed plugs and wires about 3000 miles ago
Old 03-08-2013 | 01:02 AM
EFOSTER's Avatar
There isn't any sensor on the tail shaft
The only one I could find was the one on the rear end
Old 03-08-2013 | 08:11 PM
Does your trans have three plugs with wires, two on the driver's side and one on the passenger side ?
Old 03-09-2013 | 01:14 PM
EFOSTER's Avatar
It ended up being fuse 8. I should have checked the simplist thing first.
kenny21
08-01-2012 11:14 PM
opium
01-10-2008 12:50 PM
Patrick@hmsga.com
12-10-2007 10:00 PM
Big99Expo
09-14-2007 01:31 AM
5literjay
10-15-2005 03:05 PM
