thud, thud sound when accel. slowly
Old 02-25-2008 | 10:49 AM
odie01's Avatar
Default thud, thud sound when accel. slowly
I have a 2004 F150 5.4 with tow package. The trans seems to be working normally with no noticable slippage, but their is two thuds that feel like slop in the driveshaft or rearend.
This occurs on slow accellerations only, is this normal
Thanks,
Steve in FW TX
Old 02-25-2008 | 02:52 PM
FordinmyVeins's Avatar
Default RE: thud, thud sound when accel. slowly
i would crawl under it and inspect your u-joints, just grab your driveline and twist it whilst in park with parking brake set. see if it moves, its gonna move a little but your looking for movement in excess of normal play in the tranny and rear end. see if any parts or locking rings are missing. but sounds like a bad u-joint to me.
Old 02-25-2008 | 11:47 PM
jr78's Avatar
Could also be the splines on the driveshaft, where the driveshaft attaches to the trans and if it has a center support where they connect. Try lubing those locations which may require removing the driveshaft, if it doesn't have zerk fittings.
Old 02-26-2008 | 04:39 PM
help me's Avatar
my parents truck is doing the similar thing mostly when turning slow.they where told to change the rearend fluid and put some kind of additive in. dont know if this is the same deal or not. so just throwin that out there
Old 02-27-2008 | 12:39 AM
jr78's Avatar
ORIGINAL: help me
I assume this has a limited slip and what you are feeling is clutch chatter. If it is under warrenty they will replace the clutches if not try changing the rearend oil and add the friction modifier.
cali5hunned
04-09-2013 10:35 AM
kharlanov
12-05-2012 11:26 AM
Mookjong
12-15-2010 09:56 PM
awwphooey
07-26-2010 03:47 PM
DannyC188
01-04-2008 12:05 PM
