Trouble code P0133
Old 10-02-2006 | 11:41 PM
fordforay's Avatar
Default Trouble code P0133
I have a engin trouble code of P0133 02 sensor circuit slow response. (Bank 1 Sensor 1) I know that I need to replace a o2 sensor but I dont know which one. Can someone help
Old 10-02-2006 | 11:45 PM
fordforay's Avatar
Default RE: Trouble code P0133
Sorry I should have mentioned that this was a 1998 F150 4x4 with a 4.6 V8
Old 10-03-2006 | 02:04 AM
Bank 1 is always the same as cylinder #1.. HO2S-11 is bank 1 upstream sensor.. The down stream are called monitors.. Check the pins in the connectors for damage and corrosion..What you might want to try before buying a O2 sensor, is switch them from right to left, and you should then get a code PO153 if its a defect sensor, as it'll follow on over to bank 2
Tiffani Entrikin
10-02-2012 10:17 PM
Bronco76Ranger00
11-08-2009 09:24 PM
moefoe9
12-29-2006 07:19 PM
98 vic
08-20-2005 03:32 AM
bluecam
06-19-2005 10:42 PM
