Update Crank no start '14 XLT F150 5.0
Hey everyone. After changing fuses, I still can't get truck to start, changed Driver Fuel Module, Starter and Coil Pack connectors. I checked the fuel line leading to injectors and no fuel, checked near to tank and lines were pressurized and had fuel in it. Took tie wire and cleaned fuel line down to tank for any clogs and nothing. Stumped at the moment and thinking atm.
Also any ideas on where fuel filter is. I just got a fuel filter from Rock Auto but cant seem to fjnd the location. Any and all help is greatly appreciated. Thanks in advance
Pretty sure your fuel press regulator is inside the fuel tank. You may need to replace that entire unit ,
The best way to know before starting the job is to have someone with a scan tool capable of providing fuel press desired and ACTUAL fuel press.
That will verify if you need to replace that unit.
