Whistling noise when engine shuts off
Old 04-04-2006 | 03:19 PM
parkse26's Avatar
Default Whistling noise when engine shuts off
My 98 F-150 recently displayed TC 0455 (EVAP leak) had it checked out at the dealer, seems the top of the fuel neck had a chip in it. They wanted 385.00 to replace the fuel neck. I filled the chip in with JB weld and all is smooth and fits good just like Factory original. However before the repair and after I hear a whistling noise when I shut off the engine. I had TC cleared and still does it . What is the problem?
Old 04-04-2006 | 09:09 PM
Bullitt94's Avatar
Default RE: Whistling noise when engine shuts off
My guess is that your patch job works well enough while the vehicle is running, but once it is shut off the pressure in the tank and in the atmosphere are allowed to equal out because there is a small leak. When air gets pulled through the repaired area, it makes a whistling sound. I don't think that it is a big deal as long as the tank can build pressure while running. It is the same thing that happens when you open the gas cap at a gas station; the tank and atmophere equal out, but the pressure builds again once the vehicle is run.
Old 06-13-2006 | 04:00 AM
grizz5675's Avatar
the whistling noise could be coming from your crossover which controls fuel draw from one tank to the other,its usually an indication the crossover is going bad.
peters04mn
08-29-2012 05:08 PM
Terrence Q. Mitchell
05-09-2011 06:00 PM
bill9iron
03-26-2008 08:16 AM
aidan80
11-08-2007 11:06 PM
explanger
08-31-2007 11:19 PM
Quick Reply: Whistling noise when engine shuts off
