Won't turn over
Old 07-01-2008 | 02:09 PM
Manny2008's Avatar
Default Won't turn over
Ok folks here's my story:
I've got a Lariat 2000 F150 5.4, other day pulled into the store when I came back put the key in the truck wouldn't start, checked to see if it was battery (bought 2 months ago) and it was fine, checked all the fuses under the dash and noticed that a 5amp fuse was blown (location 20), replaced fuse and off I went, truck started right up. Got back in truck today andthe same thing, it won't start, I've replaced every single fuse all 25 of them under the dash, checked the ones under the hood and it's all good, I can't find if any where there's a relay that controls any part of starting the truck. One thing that I would like to mention is that a couple of months ago the key Fob wouldn't work completely, won't open or close doors. I'm at my wits with this one, only thing I can determine that there a short somewhere (hopefully not the computer). If anyone has had this happen to them before I would appreciate a reply and I thank you in advance.
Thank you,
Manny
Old 07-02-2008 | 05:06 PM
wow's Avatar
wow
Default RE: Won't turn over
Check ground wire to starter. See if it is tight or if it has oil leaked on it. Be sure ground wire to battery is clean and tight.
Old 07-02-2008 | 05:38 PM
Did it blow the #20 again?? That position/fuse is for the PCM/GEM and radio.. OEM radio?
Old 07-02-2008 | 07:58 PM
Manny2008's Avatar
Yes you're correct....this is the fuse that kept blowing, I replaced it and the fuse is fine now, also removed radio Samo o same o, nothing that I've done has made a difference.
ORIGINAL: Hayapower
Old 07-02-2008 | 09:07 PM
Proabaly the thing to do at this point since the fuse isn't blowing now, (and the truck doesn't start) may be to have someone hook up a scanner and see if it'll communicate with the PCM and vise versa.. Know anyone with a scanner, or even code reader to see if it'll test?
Old 07-03-2008 | 07:59 AM
Manny2008's Avatar
This is amazing........
Stuck a cheapy scanner (AutoZone Brand), did a scan and found no error codes, not a 1 and the truck started. I mean not even 30 seconds of hooking this scanner up and the truck cranked right up. I'm at a stump seems that I'll be spending a few hard earned bucks with Ford. I'll replace lock actuators being that these aren't working but I can't see how this would stop a vehicle from starting......unless maybe it has something to do with the alarm, oh well I'll be scratching my nugget for a long time over this one, thanks for all the help and I'll post the problem once it gets resolved 100%.
Manny
GreatAwakening
08-18-2012 11:47 AM
deciduous
11-04-2011 09:13 PM
jthomasrichards
06-14-2011 12:10 PM
Bernie Ramaekers
12-13-2009 10:57 PM
arcticcatsledhead
05-06-2009 03:29 PM
