"00" 250 cruise control quit ??
Old 06-15-2008 | 09:31 PM
tim.d's Avatar
Default "00" 250 cruise control quit ??
2000 F-2504x4 crew
Any ideas why it may have quit. Nothing else has quit just the cruise. It just kinda fadded out over a couple of weeks.
Thanks
Tim
Old 06-16-2008 | 01:14 AM
Default RE: "00" 250 cruise control quit ??
Check the cruise control deactivation switch/connector out on the master cylinder.. There's an current safetyrecall 05S28 for this issue, as well as a possible shorting/fire concern.. Have your servicing dealer check to see if the recall repair has been performed if you haven't been mailed the recall notification card...
Old 08-30-2008 | 03:13 AM
JB_F250's Avatar
The problem is the sending unit on the master cylinder.
The recall addresses the problem with an inline wire harnes fix but does not change the sending unit.
I put the new improved sending unit on my truck for 35.00 plust a couple minutes time and it all worked again.
On mine, brake fluid began to drip out through the electrical contacts when I unpluged it.
I suspect this unit is the source of all the mystery Ford fires.
Everyone who has not done so, should install the new improved sending unit.
Old 04-26-2012 | 01:13 PM
rahnmasonry@aol.com's Avatar
cruse quit on my2000 f250 diesel changed unit on master cylinder still no good
Old 06-26-2012 | 08:48 AM
FordNutz's Avatar
Had an issue with a 95 f150. Cruise just quit working one day. Check the switches in the steering wheel and all was ok. I took the unit out from under the hood, remove the cover to expose the inner mechanical works. A pair ar vice grips and wiggled the inner shaft antil it moved freely and some wd-40, worked prefect until the day i traded it in
ricknags
04-05-2019 03:39 PM
AbNormal27
04-22-2014 10:33 AM
ajd63
11-29-2011 02:11 PM
frankencow_1
03-10-2009 12:06 AM
AP
07-28-2007 04:01 PM
