01 250 Instrument cluster dead
Old 12-03-2013 | 10:25 PM
sectlandscaping's Avatar
Default 01 250 Instrument cluster dead
I didnt have any lights on the instrument panel. The fuses were good and the bulbs were good. After looking at everything over and over again. I hard wired the lights to a fuse. When I put it all back together. I get lights now but none of the gauges work?
Old 12-03-2013 | 11:34 PM
Sure the 5amp in the CJB is good?
So,, the cluster illumination wasn't working but the gauges were, then, after power up the cluster illumination the gauges now don't work? Any of the other warning/indicator bulbs powering on?
Old 12-04-2013 | 10:19 AM
You got it. All the warning lights worked before and after. Rather have my gauges then lights lol.
I could try swapping the fuses but they all appear to be good.
Old 12-05-2013 | 04:28 PM
Penguin98's Avatar
Is it's not the fuse 9/10 the cluster itself is junk. Just search the phrase "ford truck instrument cluster dead" and you'll find tons of people with the same issue.
Check with the dealer about getting a new one Genuine Ford Parts - OEM Ford Parts - BlueSpringsFordParts.com
I heard there was some weird odometer issue with buying an aftermarket one? I can't recall what it was exactly.
Old 12-06-2013 | 11:27 AM
I found a 10 amp fuse that appeared to work but didnt. It wasnt listed as related but you know how that goes. Ill post the fuse # when I check.
I seen people getting them rebuilt so they dont lose the mileage. These need to be programmed after installation too. The dealer price is $680.
hfb1957
01-24-2013 10:30 AM
pops296
02-28-2009 07:39 PM
sisdavid@yahoo.com
08-09-2006 12:32 PM
gpressick
07-14-2005 07:05 PM
jtt3769
06-04-2005 01:12 AM
