'06 Ford F-250 6.0L air conditioning and 4WD issues
Old 07-16-2017 | 03:31 PM
Raptor1137's Avatar
Originally Posted by bismic
Not saying that at all. You asked for help on a problem that is common. Maybe it is electrical, that is not the common issue for your problem. You asked for help and then seemed to reject it. I have no problem with that if that was your intent (and it seemed to be to me - if I misread your intenet, then I do apologize for that).
If you are willing to invest a little time, then find the vacuum pump (passenger frame rail) and the solenoid and see if you are getting vacuum. Even more simple, pull the heater line off and stick your finger on it and see if you are getting a vacuum.
If the 4WD system works w/ the hubs in manual, then the transfer case (electrically operated) and the 4wD switch are working fine. The issue then would be with your hubs alone (nothing electrical to them).
Ok, yes I'm getting vacuum, used the heater line test and the vacuum does in fact suck,
  #12
Old 07-16-2017 | 03:39 PM
bismic's Avatar
Was the A/C on when you did the test (blend door test when the A/C is on)? It should have been. Sorry not to have mentioned that. Then try it in 4WD (to test the hubs for a leak).
I would then do the same test at each hub (pull the vacuum lines - they are easily accessible from underneath) w/ the A/C on.
If that seems to indicate sufficient vacuum, then the 4WD troubleshooting guide attached should help.
I think the proper thing to do would be to put a vacuum gauge on it (with the A/C unit on) and compare it to spec. I just don't recall what the spec is at the moment.
  #13
Old 07-16-2017 | 04:27 PM
Raptor1137's Avatar
Yeah, I'll do That now
  #14
Old 07-25-2017 | 06:05 PM
bismic's Avatar
classic thread ......
  #15
Old 07-26-2017 | 12:08 AM
Dang47's Avatar
I had similar issue with my 05 F350, was a vaccum leak on one my lock out hubs. once this was replaced it worked fine.
  #16
Old 07-28-2017 | 07:41 AM
bismic's Avatar
Good post, good advice!
  #17
Old 08-04-2017 | 03:57 PM
destanley's Avatar
Replace this and you should be good: Oe Ford 7C3z9h465a 4X4 Auto Lock Locking Hub Vacuum Control Valve/Solenoid
Available on Amazon. Fits under hood, right side wall. Two minute job.
hilliad
07-04-2010 02:26 PM
cherrob123
06-23-2009 07:11 PM
Marshall
06-22-2009 05:21 AM
hopester95401
04-13-2008 01:01 PM
hopester95401
04-13-2008 01:01 PM
Quick Reply: '06 Ford F-250 6.0L air conditioning and 4WD issues
